no spark in coils
Old Dec 8, 2016 | 10:04 PM
jack gentleman's Avatar
Default no spark in coils
i have a big problem plz help
i have swapped ls3 Camaro engine to my e36 bmw after a lot of works it did fit into my car after weeks i tried to start the my car it does crank but no spark at all in plugs even i touched all of them while cranking but no spark can some help me please.:
Old Dec 9, 2016 | 01:36 AM
pantera_efi's Avatar
Default Lang Racing
Hi, Andrew (Lang Racing) is one of my customers, he's a BMW expert.
He has done many LS Conversions.
I make coils, EMS, etc.
I would like to be of help, need more information OR call Andrew.
My guess = VATS
Lance
Old Dec 9, 2016 | 01:26 PM
Thanks for reply bro
i was thinking about vatf r uh sure that ls3 have vats if it has what should i do know to disable it completely.
Old Dec 9, 2016 | 04:56 PM
Project GatTagO's Avatar
A VATS problem generally presents as a brief fire and quick shut off.
Check your grounds. Got the two grounds going to the back of each head?
Andrew
Old Dec 9, 2016 | 05:40 PM
Then i think it doesn't have any vats problem because
there is no fire at all in coils and no signal from crank sensor also. And yeah i got both grounds tomorrow i will upload pictures of wirimg and grounds etc. and thanks for reply
Old Dec 10, 2016 | 02:15 PM
Do you hear the fuel pump priming?
Andrew
Old Dec 10, 2016 | 05:53 PM
Yeah i did here fuel pump sound even i connected lamp to fuel pump when i was cranking it was getting on well my guess is there is problem related to pcm or pcm itself because pcm is not giving any signal to coils or crank sensor.
