Need help t56 1967 camaro
Old Dec 29, 2016 | 11:50 AM
kstafford's Avatar
Default Need help t56 1967 camaro
So I did a ton of research on this just cut a new shifter hole ya right😤. Ok here goes car is a 67 coupe I've had a built 5.3 in for years dumping the 3 speed auto for LS t56. Cut new hole b&m forward offset shifter works great. Now for the issue at hand I can't get a tailshaft angle any better than 3 degrees down with it smashed into the trans tunnel literally picking the car up off the lift WTF😤. So it's a mono leaf rear with track bars the rear pinion sits at 4 degrees down and I don't think I can shim it 8 degrees up. I have solid motor mounts 1" setback plates and a lot of sheet metal work ahead of me unless I am really missing something here. I have a CTSV pan that looks like it could go forward 1" but as it sits the is no way that is gonna help anything. To me it looks like 1/8 of the tranny would be sticking into the car to give me a zero degree angle. Part of me wants to say f it and see how bad the driveline vibe will be all f up.
Old Dec 29, 2016 | 12:18 PM
JoeNova's Avatar
Restricted User
There isn't anything wrong with 3 degrees down on the tailshaft.
Old Dec 29, 2016 | 12:21 PM
kstafford's Avatar
I agree but I can't shim my rear up 7 mono leaf issues.
Old Dec 29, 2016 | 12:33 PM
JoeNova's Avatar
Restricted User
4 degrees down on the rear is bad. I would worry about that more than the trans.
Old Dec 29, 2016 | 12:53 PM
kstafford's Avatar
Everything I have read says with leaf springs 4 degrees down is good.
Old Dec 29, 2016 | 05:37 PM
kstafford's Avatar
No opinions
Old Dec 29, 2016 | 05:41 PM
kstafford's Avatar
I must be getting old lol
Old Dec 29, 2016 | 07:27 PM
jimmyg's Avatar
I think Holley makes mounts that will work. Motor is sitting too high
Old Dec 29, 2016 | 07:30 PM
jimmyg's Avatar
https://www.holley.com/products/ls_p...ap_components/
Old Dec 30, 2016 | 10:22 AM
JoeNova's Avatar
Restricted User
Is your pinion angle 4 degrees down, relative to the ground, or the driveshaft?
4 degrees down from driveshaft is normal, because it doesn't necessarily mean that the pinion itself is pointing down. If your pinion is actually pointing 4 degrees down, that could be a problem.
Old Jan 2, 2017 | 03:09 PM
kstafford's Avatar
yeah its 4 down from level with the ground.
