Speed Engineering Fox swap headers?
Old Jul 10, 2017 | 09:15 PM
learning91's Avatar
i will try to get you some pics . i wasnt overly impressed with the job they did bending my exhaust, but its pretty tough to find anyone to do 3" around my neck of the woods
Old Jul 11, 2017 | 06:34 PM
learning91's Avatar
heres a few pics
Old Jul 11, 2017 | 09:53 PM
TxFireman1972's Avatar
Looks good!
Old Jul 12, 2017 | 12:20 PM
93 coupe's Avatar
Learning 91, where did you get your bands to connect at the collector and also the X pipe. BTW, the pipes look good.
Old Jul 12, 2017 | 12:24 PM
learning91's Avatar
i think i got them from Jegs...they were pretty cheap..
Old Jul 12, 2017 | 03:00 PM
dmracing's Avatar
Learning 91
Who's X pipe is that
Old Jul 12, 2017 | 10:02 PM
learning91's Avatar
the exhaust shop said it was a magnaflow x-pipe...they ordered it?
Old Jul 22, 2017 | 01:17 PM
STOCKLSPAPA's Avatar
looks great, thanks for the pics!
Old Sep 25, 2017 | 10:08 PM
foxsl's Avatar
Any of you try these headers on a fox with a stock power rack and steering shaft?
Old Sep 25, 2017 | 10:18 PM
I'm running a 2004 GT rack, but using a Maximum Motorsports steering shaft
Old Sep 26, 2017 | 06:10 AM
markster's Avatar
Im using the stock shaft but needed to weld on a smaller ebay steering u-joint. The stock rag joint would not fit between the tubes.
Old Sep 26, 2017 | 12:06 PM
  #32
foxsl's Avatar
Ah thanks for the replies guys, would it be a simple matter of just swapping out my steering shaft directly for a flaming river unit for instance?..
Such as no extra drama or mods just disconnect from the rack and steering column at the engine bay firewall side, install the new shaft into my power rack, and I'm good to go? I appreciate the help, just need to know if it's truly that drama free.
Old Sep 26, 2017 | 12:39 PM
  #33
user 4737373's Avatar
Your level of success depends on what K-member/steering shaft combination your headers were originally prototyped to fit with. All the aftermarket K-members relocate the steering rack from the stock Fox body position, which in turn draws the steering shaft along with it.
A few examples of this would be as follows:
UPR 5.0 K-member- moves the rack mounting position up .5"
AJE K-member- moves the rack mounting position down 1-1/4" and over towards the driver side by 1/4" from the stock position. The engine is also moved closer to the vehicle centerline than stock.
Team Z swap K-member- moves the rack mounting position down 1-1/4" and over towards the passenger side by 3/4" from the stock position. The engine is also moved closer to the vehicle centerline than stock.
As you can tell, there is no standard engine, steering rack/shaft position used by all K-member suppliers, so a set of headers that works well on one user's car may have considerable interference on another user's car that is using a different K-member.
Old Sep 26, 2017 | 01:11 PM
  #34
93 coupe's Avatar
I'm using a stock rack, flaming river shaft with Team Z K member, it is very tight around the u joint on shaft.
Old Sep 26, 2017 | 02:27 PM
  #35
foxsl's Avatar
Thanks for the detailed reply. I'm using an aje kmember along with all aje related parts like motor mounts and transmission crossmember. It looks like the speed engineering headers were made to work with an Aje kmember. I'm currently using a stock power rack and shaft with hedman midlength 1 3/4" headers. I shimmed my steering column so there is no rubbing. The flaming river shaft seems to be the ticket to success with the 1 7/8" headers based on what people are saying.
Old Sep 27, 2017 | 11:47 AM
  #36
96lt1m6's Avatar
Originally Posted by TxFireman1972
Anyone running the Speed Engineering Mustang LS swap headers? Thinking about ordering a set, but was wanting to see if anyone is running them already.
http://www.speed-engineering.com/fox...d-mustang.html
Attachment 591822
I looked for those headers on the site and did not see them how much are they?
Old Sep 27, 2017 | 12:15 PM
  #37
https://www.speed-engineering.com/ls...d-mustang.html
Old Sep 27, 2017 | 05:11 PM
  #38
96lt1m6's Avatar
Thanks
Not a bad price at all..
Old Sep 28, 2017 | 07:21 AM
  #39
rtagg's Avatar
Default Do they fit with Maximum Motorsport K?
I emailed Speed Engineering yesterday and asked if they knew if their headers would fit with a Maximum Motorsport K in a Fox. I was impressed that they got back to me within an hour or so, but sad to hear that they have not tested their headers with a MM K, so I'm wondering if anyone here has tried this? I'm running the MM 5.0 K, not the 4.6.
Old Sep 28, 2017 | 07:34 AM
  #40
The specific engine mounts you use will have an affect on header compatibility with the Maximum Motorsports K-member as well as the K-member itself.
