ECM mounting (LS Swap)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
I am curious to see what others have done.
Andrew
Man, I am curious too. I was working on a 69 Camaro the other day and the guy was using a 411 ECU and that damn thing is ******* huge!!! He has vintage air under the dash and there just isn't any space at all. I think he was going to have a bracket made to mount it above the vintage air and vertical in front of the glove box door. Glove box will be eliminated.
The 411 will fit- barely- above the glove box liner with vintage air in a 69. That's where I had mine mounted before I switched to an LS3/E38. You have to get creative in the wai the plugs & harness is indexed. No need to eliminate the glove box. I recently installed one in a 69 on the top of the trans tunnel hump up against the firewall. I ran the hole just inside the trans tunnel on pass side. ECM is mounted on its edge, with velcro holding it to the back side of the firewall. Vintage air unit would have to be taken loose from its mounts to put it there.
I plan to use the factory LS1 harness and lengthen it to my needs. What about in the drivers side fender on the firewall? You know, where the X stamping is? Im running Vintage Air and my bulkhead will be in the passenger side fender where the original blower motor hole was. I don't have a problem mounting it under the dash or by the trans tunnel like mentioned above but where did you run your wires through?
