ECM mounting (LS Swap)
I used the C5 mounting bracket in that spot on my Monte Carlo so that it would hold the TAC module, but the Monte Carlo has more room in that area than most GM cars of that era.
https://www.vettenuts.net/index.php?...t_detail&p=743
I was looking for some wisdom about this as someone thought it would be a good idea to just zip tie the PCM to the steering column in the LS swapped 1947 DeSoto I'm working on now. It's only a matter of time before the wires fatigue and crack and I'm chasing electrical gremlins everywhere.
I'll have to see if the harness is long enough to get to the firewall in closer to the middle of the car. If not, I'll use some u-bolt clamps on the column to attach a mounting bracket. It looks like the S10/Blazer bracket is the way to go from what I see on this thread. I actually have a few of those in the parts bins in the shop.
Rick
