LS3 Mod 49 Chevy Business coup
Old Sep 7, 2017 | 11:03 AM
  #61
ltmontana's Avatar
Originally Posted by ls1nova71
Sounds good! You look so excited but cant blame you. Here's a link so people don't have to look it up. https://www.youtube.com/watch?v=x3bhu1D4k0U
Thank You -- for doing that Larry
Old Sep 11, 2017 | 06:22 PM
  #62
Redneckinjunear's Avatar
Nice job Larry. Did you know you can eliminate the hose crossing back across the intake by flipping the fuel rail 180 degrees? No mods to make it work. Russell makes all the fittings to hook up fuel rail to AN-6 hose fittings.
It's too bad you couldn't move the engine back a little but I assume you put it there so the shifter would be in the right place. I'm to old at 76 to be shifting so I used the 4L65 that came with the LS2 I put in my 39 Chev 2d.
Old Sep 26, 2017 | 06:21 PM
  #63
ltmontana's Avatar
I was aware of that -- thank you-- Yea I'll be 71 in a few days, I hope my hands will hold out long enough to finish this, a few more pix of the shifter tunnel, more welding to do . Cold air intake is FINALY done, pain in the butt but came out real nice, fabing the council has been ben real trying but it will look nice when it's done. rear disc will fit ub nice Emergence brake is next.
Attached Thumbnails LS3 Mod 49 Chevy Business coup-p9020894.jpg   LS3 Mod 49 Chevy Business coup-p9030899.jpg   LS3 Mod 49 Chevy Business coup-p9120800.jpg   LS3 Mod 49 Chevy Business coup-p9130805.jpg   LS3 Mod 49 Chevy Business coup-p9130815.jpg
LS3 Mod 49 Chevy Business coup-p9130836.jpg   LS3 Mod 49 Chevy Business coup-p9200857.jpg   LS3 Mod 49 Chevy Business coup-p9230867.jpg   LS3 Mod 49 Chevy Business coup-p9230870.jpg
Old Oct 15, 2017 | 12:05 PM
  #64
ltmontana's Avatar
A few more pix, finally finished fabing the tunnel support for the council. This is in 5 pieces and is removable, was a lot of work to do--- kicked my butt for a wile but supports the council well enough so when someone leans on it it won't crack it. The next project is to relocate the clutch & break pedals.
Attached Thumbnails LS3 Mod 49 Chevy Business coup-pa100996.jpg   LS3 Mod 49 Chevy Business coup-pa100995.jpg   LS3 Mod 49 Chevy Business coup-pa110998.jpg   LS3 Mod 49 Chevy Business coup-pa140004.jpg   LS3 Mod 49 Chevy Business coup-pa140001.jpg
Old Nov 16, 2017 | 10:38 PM
  #65
ltmontana's Avatar
A few more pix of of the build, drive line all fabed and installed , lots of shots of S/S 3" mandrel bent exhaust, all Tiged together. Started this today with the system all welded together --- sounds great
Attached Thumbnails LS3 Mod 49 Chevy Business coup-pb010108.jpg   LS3 Mod 49 Chevy Business coup-pb010112.jpg   LS3 Mod 49 Chevy Business coup-pb060119.jpg   LS3 Mod 49 Chevy Business coup-pb070141.jpg   LS3 Mod 49 Chevy Business coup-pb110203.jpg
LS3 Mod 49 Chevy Business coup-pb110208.jpg   LS3 Mod 49 Chevy Business coup-pb110213.jpg   LS3 Mod 49 Chevy Business coup-pb110207.jpg   LS3 Mod 49 Chevy Business coup-pb140214.jpg   LS3 Mod 49 Chevy Business coup-pb140224.jpg
LS3 Mod 49 Chevy Business coup-pb010106.jpg   LS3 Mod 49 Chevy Business coup-pb110198.jpg
Old Nov 16, 2017 | 10:58 PM
  #66
Nice work overall, but GORGEOUS exhaust work! Had to put the shades on, man! lol
Old Nov 18, 2017 | 08:22 PM
  #67
Motown 454's Avatar
I agree with G Atsma excellent work on all of it.
Old Nov 19, 2017 | 10:04 AM
  #68
ltmontana's Avatar
Thanks for your input, seems like a lot of people look at these posts ( not just mine ) and never comment.
Old Nov 19, 2017 | 10:34 AM
  #69
AnotherWs6's Avatar
Of course they do. Imagine if everyone who looked commented, this thread would be 200 pages long.
Looks like you're doing some nice work. The H-pipe in your exhaust is pretty trick looking. Subscribing to this one, can't wait to see it all done.
Old Nov 20, 2017 | 03:04 PM
  #70
ltmontana's Avatar
Your right, didn't think of that.
Old Nov 20, 2017 | 03:28 PM
  #71
5deuce's Avatar
Subscribed, great work with this so far...
Old Dec 12, 2017 | 06:07 PM
  #72
ltmontana's Avatar
A few more pix of the progress-- filled in the recess from the old plate, lots of lead that needed cleaned off to be able to weld in patch plate, Old friend of mine did this in 1988, kinda didn't want to do away with the memory. Charcol can brackets we re fabed from lighter material -- ready to weld in. Proportioning valve bracket ready to weld on. Iv'e kinda run into trouble finding a place to paint all this--but im sure i'll figure it out
Attached Thumbnails LS3 Mod 49 Chevy Business coup-pc060245-1-.jpg   LS3 Mod 49 Chevy Business coup-pc060246.jpg   LS3 Mod 49 Chevy Business coup-pc060247.jpg   LS3 Mod 49 Chevy Business coup-pc100251.jpg   LS3 Mod 49 Chevy Business coup-pc100261.jpg
LS3 Mod 49 Chevy Business coup-pc110277.jpg   LS3 Mod 49 Chevy Business coup-pc120280.jpg   LS3 Mod 49 Chevy Business coup-pc120284.jpg   LS3 Mod 49 Chevy Business coup-pc120288.jpg
Old Dec 12, 2017 | 10:50 PM
  #73
Motown 454's Avatar
It looks good!
Old Dec 27, 2017 | 10:15 PM
  #74
ltmontana's Avatar
A few more pix---- pulled the engine wiring harness and boxed it up, started fabing pieces for the Camaro e-brake set up---- this should work out nice. Cut out old ignition switch hole to smooth dash for ididit steering column with key in column.
Attached Thumbnails LS3 Mod 49 Chevy Business coup-pc180310.jpg   LS3 Mod 49 Chevy Business coup-pc190311.jpg   LS3 Mod 49 Chevy Business coup-pc190313.jpg   LS3 Mod 49 Chevy Business coup-pc190316.jpg   LS3 Mod 49 Chevy Business coup-pc200321.jpg
LS3 Mod 49 Chevy Business coup-pc200323.jpg   LS3 Mod 49 Chevy Business coup-pc270356.jpg   LS3 Mod 49 Chevy Business coup-pc270359.jpg
Old Dec 28, 2017 | 10:35 PM
  #75
Motown 454's Avatar
Nice progress, it's all looking good.
Old Dec 29, 2017 | 05:23 PM
  #76
ltmontana's Avatar
A couple of pix of the little adapter block for the e- brake, and some engine pix. This has been quite a project, one little job after another, but most of the heavy fab stuff is done, I hope.
Attached Thumbnails LS3 Mod 49 Chevy Business coup-pc290373.jpg   LS3 Mod 49 Chevy Business coup-pc290374.jpg   LS3 Mod 49 Chevy Business coup-pc280363.jpg   LS3 Mod 49 Chevy Business coup-pc280368.jpg   LS3 Mod 49 Chevy Business coup-pc280365.jpg
LS3 Mod 49 Chevy Business coup-pc280371.jpg   LS3 Mod 49 Chevy Business coup-pc280369.jpg
Old Jan 6, 2018 | 06:13 PM
  #77
ltmontana's Avatar
E-brake final fit up, came out nice, rear bracket will get welded into floor board.
Attached Thumbnails LS3 Mod 49 Chevy Business coup-p1020378.jpg   LS3 Mod 49 Chevy Business coup-p1020377.jpg
Old Jan 6, 2018 | 06:19 PM
  #78
Motown 454's Avatar
It came out nice, Coming together.
Old Jan 6, 2018 | 09:31 PM
  #79
CattleAc's Avatar
Yeah, looks really good...love your stickin' with the manual trans.
Old Jan 16, 2018 | 01:43 AM
  #80
1985fiero's Avatar
do you have any pics on how tight that sd7 ac compressor and dirty dingo mounts were?
