FEAD? Which is best
Old Jan 26, 2017 | 08:28 PM
461rat's Avatar
Default FEAD? Which is best
I've searched, but a lot of the info is dated. And want to know, if starting from scratch, which one would everyone choose? The truck for availability and $$ or the Vette for looks? Or the Camaro for $$ and the best of both?
I'm trying to put together a FEAD for my 68 Chevelle, and am torn with used vs, gm new ( Pace or Gm equivalent) for piece of mind and looks. What's everyone's opinions?
Old Jan 26, 2017 | 09:17 PM
user 4737373's Avatar
It depends on the specific engine mount set-up you are using.
Old Jan 26, 2017 | 09:44 PM
gofastwclass's Avatar
Plus your goals, concern for looks and budget.
Old Jan 26, 2017 | 09:46 PM
Senna's Avatar
The Corvette FEAD is probably the simplest. But I don't think it looks that good, The Alt is just way to out to the side.
The F body set up is clean looking, but there are questions on if it will fit. Engine placement matters. Holley just released low mount Alt style that looks good.
Old Jan 26, 2017 | 10:55 PM
01cherryreds10's Avatar
Holley 20-135 and then either the matching bracket for the compressor of your choice (sanden or r4), or the gm low mount compressor to match whatever spacing you want to run.
If you are starting over i would say your best bet is to look at all comparable vehicle swaps here of your vehicle and look at everyones header, pan, and mount combos.
In my impala im using an LSA blower with an lsx concepts tensioner setup, and for the accessories using the holley bracket, with corvette spacing and using a high mount sanden bracket also from holley.
In my malibu i was using the holley bracket with ls1 spacers, but found out i could use a low mount compressor from a truck. so switching to the truck spacers for the holley bracket and using water pump spacers to get the ls1 pump to use the truck spacing.
Very confusing i know, lol.
Old Jan 26, 2017 | 11:12 PM
jimmyg's Avatar
68 chevelle, you might run into problems with ps box. I would look at what everybody else is running in your application
Old Jan 26, 2017 | 11:37 PM
You can run the OE 4th-gen F-body FEAD if you are using 1" set-back engine mounts, If they happen to merely be flat adapter plates that work with the stock frame stands, that will cause issues with running a low-mount A/C compressor if you are wanting to do so. The new Holley low-mount alternator set-up is subjected to the same engine set-back requirements. You can use the truck FEAD by switching out the PS pump pulley for one from a early 90's V6 Camaro. The Corvette FEAD fits at any fore/aft engine positioning. If you want to run a low-mount A/C compressor, the unique design geometry of the Hooker A-body engine brackets will allow you to do that.
Old Jan 27, 2017 | 07:31 AM
461rat's Avatar
I am running the Holley forward mount engine brackets.
Old Jan 27, 2017 | 08:29 AM
Knowing that clarifies the options available to you...you can run Corvette/Holley high-mount alternator set-ups, or the truck FEAD by swapping out the PS pump pulley. You can run a low-mount A/C compressor also if you wish to.
Old Jan 27, 2017 | 10:41 AM
slowman's Avatar
I think the Billet Specialties looks the best! Here's an LS3 engine package we recently finished up for a customer. Really liked the look.
Old Jan 27, 2017 | 10:45 AM
That is an attractive set-up, but it would not be installable with the engine mounts the OP is using.
Old Jan 27, 2017 | 10:47 AM
slowman's Avatar
Ahh, got ya!
Old Jan 27, 2017 | 06:40 PM
Senna's Avatar
Why is that Todd? I was planning on using the Wegner motorsports FEAD that is very similar to the one posted above.
Mine is a 66 with HOLLEY forward biased mounts
Old Jan 27, 2017 | 07:20 PM
The reason for non-compatibility is due to interference between the steering box and any accessory drive component that resides in the low driver side area. When the Hooker forward-bias engine brackets are used, the accessories must be configured to hang above the steering box (Corvette type configuration). The Hooker rear-bias engine brackets put the accessories in that area behind the bulk of the steering box, which opens up more options for accessory drive set-ups. That comes with the trade-off of poor transmission fitment for late model transmissions however and the inability to achieve optimized U-joint working angles with said transmissions.
Old Jan 27, 2017 | 07:33 PM
Senna's Avatar
Damit!!!
Old Jan 27, 2017 | 07:36 PM
Damit!!!
Your other option is the OE truck FEAD with a swapped smaller diameter PS pump pulley.
Old Jan 27, 2017 | 07:49 PM
Hey Senna, I want to be sure the information does not get mixed up between the 64-67 and 68-72 A-body applications...the 64-67 cars cannot use a low-mount alternator FEAD with either or the Hooker engine bracket sets due to the closer proximity of the steering box to the firewall compared to the 68-72 A-body application. The Hooker rear-bias engine brackets for the 68-72 A-body are the only ones that will permit the use of a low-mount alternator. I did not test fit the Wegner system as part of my development efforts and could be wrong in my assessment...but I'm fairly confident it won't fit.
Old Jan 27, 2017 | 08:18 PM
68conv455's Avatar
Todd,
Anyone in your office know when the Holley 20-143 kit will be available?
Old Jan 27, 2017 | 09:39 PM
Senna's Avatar
Mine is a 66 with forward biased mounts.
I really like the wegner set up, their application chart says it fits a 66 but the chart also says it fits just about every car out here.
I'll have to call them to find out specifics.
Old Jan 28, 2017 | 06:23 AM
Originally Posted by 68conv455
Todd,
There would be purchasers and product managers that would have estimates about that type of info, but It's not something I follow as part of my job functions.
