LS6 powered 1978 trans am restomod!!
Old 02-05-2017, 05:25 PM
moekluse's Avatar
Quarter is almost done
Trunk pan is done as well
Old 02-10-2017, 07:54 PM
moekluse's Avatar
Haven't posted in a while.. both floors are about done, as well as most of trunk floor. Will start removing old engine/trans/subframe tomorrow!
Old 02-11-2017, 07:14 PM
Jimbo1367's Avatar
If the quarts were the same fix, great job.
Old 02-11-2017, 07:33 PM
moekluse's Avatar
Got everything disconnected in order to pull tranny out (steering shaft, drive shaft, shift cable, powersteering hoses, brake lines..etc) will be dropping engine/trans/subframe tomorrow morning with pics
Old 02-12-2017, 10:15 AM
moekluse's Avatar
Motor and trans are out
Old 02-14-2017, 10:08 AM
2slowTA's Avatar
Originally Posted by moekluse
Does anyone know if there's a companyout there that make tube k members? My subframe is alright but looking for more strength and rigidity
Tube sub frame? Havnt never heard of that unless it is new. Detroit speed makes a hydaformed sub frame which is made to accommodate big wheels, LS motors, rack and pinion, blah blah blah. Much better than oem but, I hope the wallet is fat. LOL
Old 02-14-2017, 10:22 AM
moekluse's Avatar
Thanks, it's about 8 grand, not too bad but I'd rather spend it elsewhere, I'm already have a 4 link kit from ride tech and it came with shocks, as well as upper and lower control arms. It's almost 4k, and comes with pretty much all the suspention components I need
Old 02-15-2017, 01:59 PM
2slowTA's Avatar
You're going the exact same route that I am. Should be a good set up.
Old 02-15-2017, 02:09 PM
moekluse's Avatar
Are you going t56? If so, which one? Brp said any t56 will fit but not sure how far back a magnums shifter will be. Do your happen to know?
Old 02-21-2017, 11:07 AM
2slowTA's Avatar
Going auto for now. If I come across a Magnum for reasonable, I'll entertain the idea. A T56 needs too much of "this and that" to work well in my opinion. So, no info on your application.
Old 02-25-2017, 11:42 AM
moekluse's Avatar
Just thought I'd update
This is an old pic, its welded in now
And its original color was gold!I didn't take a pic, but the firewall, doors..etc have been epoxy primed
Old 03-22-2017, 04:37 AM
  #32
moekluse's Avatar
Ok! Here's an update:
New door skins on both sides, just trying to adjust them now
New hinges and hardware all the way around
New polyurethane subframe bushings have arrived.
next steps are to drop subframe and rear end so I can seal the bottom of the car, then get ready for 4 link kit, I'm going to need to find a new rear end, this one's lsd but probably won't hold with the power I'm planning
Old 04-10-2017, 07:17 PM
  #33
moekluse's Avatar
Haven't updated in a long time so I thought I'd share some new Info. We finally decided on a pair that color. We were expecting to go with silver but instead, we have decided to paint it the same color as the dusk edition camaro. It looks black at night, and blue in the sunshine, it's super nice but it's over 600 bucks a gallon! Too late, already purchased haha. Floor, quarters, fire wall, trunk..etc are pretty much complete. We installed new skins on both doors. Just getting them shaped up and adjusted.
Old 04-12-2017, 05:56 PM
  #34
moekluse's Avatar
Dropped rearend, sway bar, and leaf springs
Old 04-14-2017, 11:19 AM
  #35
Jimbo1367's Avatar
I wish you had more pics showing the rocker replacement.
Old 04-14-2017, 12:09 PM
  #36
moekluse's Avatar
I will take some this afternoon, I don't have any pics of the old one, it was just cut off.
Old 05-12-2017, 06:43 AM
  #37
moekluse's Avatar
Haven't updated in a month...wow. alrighty, here's my progress so far...
Rear end was all done up. New posi center section, 3.73 gears, and all new bearing and seals...as well as that sexy b&m rear end cover
New shocks, 1.5 inch drop hotchkis leafs, all new bushings, leaf spring pearches..etc
as you may see below the car is the subframe. It was also painted. The cpp upper and lower control arms will be here today, as well as the QA1 front coil overs.
the tr6060 I ordered should also be here today.
We're going to go pick up a disassembled 5.7 ls1 because I feel like the 5.3 will be a bit too heavy.
here's some underbody shots
brp hotrods kit is installed
Old 05-12-2017, 11:16 AM
  #38
Jimbo1367's Avatar
Looks good. Did you have to brace the body any to replace the rocker? I'm considering to try this VS. just cutting out the previous owners jacking F* up.
Any other pics showing your rocker during replacing it would be appreciated. Any advise?
Thanks,
Jim
Old 05-12-2017, 11:49 AM
  #39
moekluse's Avatar
Thanks,
Jim
I did not brace the body, I replaced everything separately, I replaced the floor before the rocker to add some structure to the car. I cut it out and welded the new one from both sides, from the front and the back, top to bottom. Solid as a rock. Then I welded a plate on the back of the rocker where the fender well is. Not to difficult but very time consuming. How bad are the rockers you have now? The dents in my old one could be fixed but there was some rust so we replaced it.
Heres an old pic
Old 05-12-2017, 12:49 PM
  #40
LSACOBRA's Avatar
Great thread! what did you use to coat the underbody of the car? everything looks really great so far. Im glad that youre using the magnum and nto an auto. For my LSA swap in my cobra im also using a tr6060.
Quick Reply: LS6 powered 1978 trans am restomod!!
