GenIV BCM/VATS disable
Swapping a L92+6L80E from an 08 escalade into my land cruiser. I intend to wire up enough of the BCM to use it for cruise control and TUTD shifting (and if possible P/N starter interlock and reverse lights, but these are secondary goals).
I seem to remember reading somewhere that if a VATS disable is done on the PCM that it will no longer communicate with the BCM. I can't find that thread anymore.. and no idea whether it applies to certain PCMs and/or different tuning software types or not.
Does anyone know anything about this?
Thanks for any help.. this place is quite an awesome resource
-Justin
There is also an update to the 6L80 with the '14 stingray that gives shift times around 200ms. Mostly software/'TCM' but some changes supposedly to the valve body.
Good luck..
However, there are a couple cases I've found (online) of the BCM being wired up to control those functions just fine.. and another case of someone seemingly reputable on here giving the advice repeatedly that wiring in the BCM is the cheap/easy way to get those functions on a E38 ECU.
https://ls1tech.com/forums/conversio...l#post14738394
http://www.fourwheeler.com/how-to/13.../photo-17.html
Basically, I'm not giving up yet.
When you do it, is anything special needed with BCM calibration? or just give it power/ground, relevant switch wires, GMLAN hookup, and it works?
Does VATS delete present any problems?
