need advise
Old Feb 28, 2017 | 07:06 PM
joseB's Avatar
Default need advise
hello i have a 1980 malibu with 6.0,4l80 trans.out of a 03 express van working real good.
the issue i am dealing with is fuel level gauge.
i did use the stock van fuel pump assembly on malibus tank ,but gauge is not reading real fuel level
gauge is a auto meter compatible with gm sending unit 0-90 ohms
any one knows how to wire it?
ill apreciate any help
thanks.
Old Mar 1, 2017 | 07:23 AM
1964SS's Avatar
First thing I would do is test the signals from the fuel level sender itself. There really isn't any trick to wire a 0 to 90 fuel sender. besides power it's a single signal wire that connects to the sender in the tank and then the sender needs a reference ground. Looks up your gauge manual. it should have a diagram for you.
Old Mar 1, 2017 | 08:00 AM
ls1nova71's Avatar
A 2003 Expressvan doesn't have a 0-90 ohm sender, theyre like 240- something. If your gauge wont work with that sender you may need to get one that will.
