ls starter conversion question
Old Mar 5, 2017 | 11:43 AM
solo20's Avatar
Default ls starter conversion question
ls3 engine with a 4l80e . iam looking at many starters online most come with a connecter they remove the ring terminal post do they sell one with the ring terminal post I don't want to cut my wires up unless I really have to anybody have a part number that works with a ls engine
Old Mar 5, 2017 | 12:18 PM
Jimbo1367's Avatar
I'd ditch the ring terminal and wire it to the Gm pigtail you can buy. SUPER SIMPLE. You will be glad you did with the simple connection of the pigtail vs. having to use a wrench to tighten it the old way.
A 10-15 Fbody 6.2L starter and pigtail are pretty cheap. manual OR auto. Try a SEARCH. There's a thread on this. I went this route with my 70 camaro LS swap.
Old Mar 5, 2017 | 12:45 PM
Project GatTagO's Avatar
What Jimbo said. The 10-15 Camaro starters also have a nifty little heat shield that bolts right to it. That's a dealer item, but cheap, and so are the bolts for the heat shield.
Andrew
Old Mar 5, 2017 | 12:46 PM
solo20's Avatar
simple going that way but I don't want to cut my wires up just in case I want to go back to stock spent a lot of money on OEM wires but cant find any part numbers for a ls starter with terminal post do they even make them like that
Old Mar 5, 2017 | 12:51 PM
Pick a slightly older vehicle, they will all have a post terminal. Look up a 2008 truck.
Andrew
Old Mar 5, 2017 | 12:54 PM
http://www.rockauto.com/en/moreinfo....441037&jsn=626
Old Mar 5, 2017 | 01:00 PM
solo20's Avatar
thanks will post back with info if it fits for the next guy who doesn't want to cut there OEM wires up
Old Mar 5, 2017 | 01:04 PM
It would be super helpful to know what kind of car you are working on. Saying "OEM wiring" is pretty useless without that tidbit of information.
Andrew
Old Mar 5, 2017 | 02:26 PM
solo20's Avatar
1964 impala
