95 lbs of fuel pressure
Old May 13, 2017 | 01:34 PM
stevieturbo's Avatar
it say's there's a second page...but it wont load ?
weird..there is now with this post lol
Old May 14, 2017 | 08:59 PM
learning91's Avatar
Aeromotive Universal Bypass Regulators 13129 i think i might use this regulator
Old May 14, 2017 | 09:07 PM
truckdoug's Avatar
i use that one. I have it at 4 bar base with a 1:1 rise with boost. works great.
one thing you may want to note though is that it has -6 ORB inlet/outlet/return
which might restrict you down the road if you wanna play with turbos and corn fuel
Old May 14, 2017 | 09:09 PM
learning91's Avatar
ok good to know! i appreciate the info ..it looks to review well but something about unclear instructions seems to come up a few times?
Old May 14, 2017 | 09:10 PM
truckdoug's Avatar
Sorry to hear it didn't work out...
I’ve used this Mallory unit on 4 builds now and not had any issues. That’s with E85 and a 4303 pump. The one on my rx7 has been going for 6 years or so now.
https://www.summitracing.com/parts/msd-29389
thats nice. -8 fittings
Old May 14, 2017 | 09:13 PM
truckdoug's Avatar
yeah there's several ways to plumb it.
i run my feed in the right hand port, left hand port to my single inlet stock truck fuel rail, bottom port is always the return/bypass
pressure sensor on the front, boost pressure to the lil snooter thing on the side
i didnt even adjust it lol it came set to 4 bar
Old May 14, 2017 | 09:33 PM
Forcefed86's Avatar
hey forcefed..i had thought you were saying your fpr was less expensive? its more than the holley plus now i have to add a filter in this mix!...the cash is just flying outta my rear!!
That's the cheapest one I've found that has a 1/2 fittings to support the power I needed on E85.
You can buy a cheapie china 3/8 adjustable regulator for around $30. I've used alot of them over the years and never had an issue on pump fuel. The aeromotive copies are the ones I used.
like these
http://www.ebay.com/itm/Adjustable-F...tY8PYK&vxp=mtr
Old May 14, 2017 | 10:10 PM
learning91's Avatar
got ya forcefed...i looked at this one too..as it has 8ans
http://www.ebay.com/itm/ZZZ-BLACK-hi...1SjY-h&vxp=mtr
but idk?
Old May 16, 2017 | 11:02 AM
truckdoug's Avatar
like these
i love that is says "well made" right in the auction title lol
Old May 16, 2017 | 11:07 AM
I just couldn't trust any Chinese stuff like that for a critical component !
And never leave those gauges installed full time in case they break
Old May 17, 2017 | 07:13 AM
learning91's Avatar
yea, i bought the Aeromotive Universal Bypass Regulators 13129. hopefully that will do the trick.
Old May 18, 2017 | 09:17 PM
  #32
learning91's Avatar
well i installed the 13129 regulator and a filter...out of the box i had 48psi after a slight adjustment wallah! 59/60psi!!!!!!!!! Hur-friken-ray!!..drove it down the road and romped on it a few times and never went below 59....so there you have it...i would like to take a moment to thank all that helped in this insane quest for 60psi...now on to other issues!! lol
Old May 19, 2017 | 06:33 PM
  #33
truckdoug's Avatar
nice. hopefully this saves someone else the dickin around with bullshit. just go straight to the right stuff and move on. ( i did the same stuff you did btw)
Old May 19, 2017 | 10:28 PM
  #34
learning91's Avatar
lol, yea i thought i was trying the right stuff! go figure..i think that holley filter/reg is misrepresented bigtime!!!
Old May 20, 2017 | 11:37 AM
  #35
LilJayV10's Avatar
I'm glad you got it figured out Marty. That's strange that the regulator wasn't enough for the pump.
I just finished a Holley Sniper install on a 69 Camaro using Holley's drop in 420lph pump and didn't have any problem. The Sniper uses the same regulator as the Holley regulator you were using. IIRC it's actually a OEM GM regulator.
Regardless I'm glad you got it figured out.
Old May 20, 2017 | 04:06 PM
  #36
4EyedTurd1's Avatar
I just ordered the 13129 regulator to avoid the same headache and knowing I plan on a turbo in a year or so. Plus it was suggested on sloppy mechanics.
