Corvette filter/regulator issue
Old Mar 26, 2017 | 05:31 PM
Chris Henson's Avatar
Default Corvette filter/regulator issue
Finishing up an LS1 install on a 94 Jeep yj. If I hook up the filter regulator (from Speedway) the right way middle larger line in the middle to pump (wet Walbro 255) and the return line to the outside small diameter fitting I get 0 pressure. If I hook them up opposite I get 60 psi on the auto meter that's.
Bad filter/reg?
Old Mar 26, 2017 | 06:28 PM
dcd215's Avatar
The center is the return
Old Mar 26, 2017 | 06:50 PM
Michael Yount's Avatar
The "right way" is the way that gets you 58-60 psig on the outlet Chris.
Old Mar 26, 2017 | 09:17 PM
learning91's Avatar
dont feel bad Chris..i just went through this, thought i had it wrong had 95 psi hooked it up right way had zero...so somethings i read were NOT true...my filter has infeed from tank on outside of the reg/filter return in the center..says so on the filter but i asked and looked a few pics that showed the opposite..so i tried it..guess what i had it right the first time...sooo i learned the hard way!..it looks like i have a bad reg/filter..good luck!
Old Mar 26, 2017 | 09:23 PM
Project GatTagO's Avatar
I only buy AC Delco of WIX. Offset is in, center is return.
Andrew
Old Mar 27, 2017 | 01:16 PM
TipsyMcStagger's Avatar
In my notes, I've have written that regardless of how the two are oriented on the filer/regulator, 3/8" is the SUPPLY from the tank and 5/16" is the RETURN to tank.
Tipsy
