LQ OIL Cooler
Old Mar 27, 2017 | 07:58 PM
DirtyChevy's Avatar
Default LQ OIL Cooler
On my 2005 LQ swap into a 1968 Camaro do I need the oil coolant tubes that run up by the radiator? I did a broad search on google and some said cap it while others said use it. Theres also a relocation kit in the classifieds right now that kind of got me wondering. I made it about 10 posts in trying to find an answer then this popped up so figured id use it.
Old Mar 27, 2017 | 08:10 PM
truckdoug's Avatar
nah you dont need em unless youre towing or making sustained high speed runs. street and strip use in a non-filled block oil temps will be fine
Old Apr 2, 2017 | 12:47 PM
DirtyChevy's Avatar
Thank you thats what I needed to know
Old Apr 2, 2017 | 03:26 PM
tfi racing's Avatar
Don't forget to get the GM block off plate for your oil pan,you just can't make your own plate or plug the holes.
Old Apr 2, 2017 | 05:19 PM
DirtyChevy's Avatar
I just ordered the Holley retro fit pan. I don't know what it comes with but ill remember to look for that.
