Upgrading a 67 Pontiac Tempest
Old Apr 7, 2017 | 12:04 PM
RockCar67's Avatar
Default Upgrading a 67 Pontiac Tempest
Hello. I am having a hard time finding the correct radiator needed for the engine swap I am doing on my car. I am putting in a 5.3 lm7 truck motor from a Silverado and 4l60e chevy trans. What would work good with this?
Any and all suggestions are welcome.
Thanks.
Old Apr 7, 2017 | 08:38 PM
Project GatTagO's Avatar
There are a dozen companies that make LS swap radiators for A-bodies. You're not looking hard enough.
Andrew
Old Apr 7, 2017 | 09:09 PM
jjamm7667's Avatar
my stock 71 monte radiator works perfectly
Old Jul 3, 2018 | 02:40 PM
ls1CANTU's Avatar
My 5.3 laid down 499.6 RWHP with our ported 243’s, Holley High Ram.
Old Jul 3, 2018 | 02:49 PM
jeffs55chevy's Avatar
i used a stock 2002 sierra 1500 radiator in my 69 chevelle. i just had to cut brackets and make new fan mounts.
Old Jul 3, 2018 | 02:55 PM
B52bombardier1's Avatar
Cold Case makes a good LS swap radiator that has all welded tanks - no epoxy. You will need to make some provision for a steam line port from your engine to either the radiator or a radiator hose. Are you retaining that gigantic LM7 fan or going with electric fans? Its all electric for me with a very good shroud for pulling the air through. I'm picking a radiator with the input and output connections both on the passenger side because my LM7 water pump will work best that way . . . shortest hose lengths.
Rick
