O2 sensor interchangeable
Old Jul 1, 2018 | 07:23 PM
33willys's Avatar
Default O2 sensor interchangeable
Long story short, have oxygen sensors that have a different plug than my harness. Can I cut and splice an older LS (2000) into a 2005 harness? Any difference for 5.3 to 6.0 sensors? Are all OEM sensor created equal?
Old Jul 1, 2018 | 09:34 PM
B52bombardier1's Avatar
Some are heated, some are not. Some have more wires than others.
Rick
Old Jul 2, 2018 | 07:41 AM
33willys's Avatar
Let me restate my question. Will the O2 signal from a 2000 Silverado 6.0 be the same as from a 2005 Trailblazer 5.3 O2 sensor? Both have 4 wires, same colors but plugs and UPC are different.
Old Jul 2, 2018 | 11:00 AM
79LS1FOX's Avatar
why not just buy the 05 sensors new they're pretty cheap?
Old Jul 2, 2018 | 03:52 PM
33willys's Avatar
My thoughts exactly but the guy I'm doing this for is hell bent on using the ones he got with the engine. I guess all the OEM O2 sensor output are the same. Nobody seems to know for sure.
Old Jul 2, 2018 | 03:56 PM
Tell him you have to use the ones that work best with the system being used. The customer is NOT always right....
Old Jul 2, 2018 | 06:36 PM
ls1nova71's Avatar
Is he hell bent on using the oil and filter that came with the engine too????
Old Jul 2, 2018 | 06:43 PM
LOL!! Good one, ls1nova71! On point, though! O2 sensors are consumable service parts, just like belts, hoses, and other sensors.
Old Jul 2, 2018 | 08:59 PM
33willys's Avatar
You have NO idea how close to the truth you are!!!!!!
Old Jul 2, 2018 | 09:32 PM
In which case, as the "automotive service professional", you put your foot down and advise the common sense course of action, rather than any alternative.
Old Jul 2, 2018 | 11:11 PM
jmd's Avatar
jmd
Charge for the wiring work.
Twice if it doesn't work out.
Old Jul 3, 2018 | 04:30 PM
33willys's Avatar
No good deed goes unpunished. Here is what I found on the underdash part of the harness. All pink power wires were gobbed together, injectors, MAF, trans...etc.
