VSS hookup?
Old Apr 10, 2017 | 12:01 PM
darren roar's Avatar
Default VSS hookup?
I have 2 LS swap projects going on. Neither one I've hooked up the VSS wire up in. I've de-pinned stock harnesses on both and I've ran the VSS wire thru a relay like the instructions on lt1swap. The question is, do I connect that wire to the brake light swith?
Old Apr 10, 2017 | 12:14 PM
Suncc49's Avatar
I think you mean TCC??? .... you definitely dont want to wire your vehicle speed sensor using a relay heh
Old Apr 10, 2017 | 12:33 PM
1964SS's Avatar
As said above the VSS will never go to a relay. That is your speed sensor.
Old Apr 10, 2017 | 01:18 PM
Suncc49's Avatar
Really need a bit more information.... are you going to keep drive by wire? VSS will need to be wired from the harness to a sensor... in my Nova project I used the dakota digital adapter that keeps cable speedo...
Old Apr 10, 2017 | 06:07 PM
I was wrong I meant TCC my bad, lol!
