Another junkyard relay block
Old May 17, 2017 | 06:40 AM
4EyedTurd1's Avatar
Default Another junkyard relay block
While out at the pick and pull shopping I found mid to late 90's Ford Explorers had a dedicated relay block mounted on the passenger frame rail. It's right under the air box. It measures 5"x2"x 3.5" at the tallest point. Most of the ones I saw had 5 relays with an open socket where you could put a 6th and it was 4 of the small relays and one large one. The one I grabbed is the only one I saw that had 3 large relays and 2 small. I have no idea of the current capacity of either size but assumed the larger ones will carry more. I thought it would be worth sharing.
