LS3 swap brake problems
Old May 29, 2017 | 06:00 PM
77cutlassLS3's Avatar
Default LS3 swap brake problems
Recently had an LS3/4L80E tranny swapped into my 1977 olds cutlass supreme. At the same time I had the brakes upgraded to 4-wheel disks from a newer caddy, with a proportioning valve. Ever since that the brakes work decent but the pedal goes almost all the way to the floor with little resistance before they engage. The shop that did the work says it's a vacuum problem but most mechanics I've talked to say that if it didn't have enough vacuum it would have a rock-hard pedal. SOMEBODY HELP!
Old May 29, 2017 | 08:17 PM
jozw30's Avatar
If they are the caddy rear calipers with parking brakes, you don't have them adjusted enough. Spent two months screwing around bleeding and bleeding and adjusting those things.....
Then found out you have to remove the parking brake lever and use a wrench on it to get them adjusted fully asjusted. Did this and have had great brakes ever since. Using vice grips on the levers won't get it done.
You will have to have a parking brake connected as well to keep them adjusted properly as they wear.
Old May 29, 2017 | 08:29 PM
1989GTA's Avatar
"Then found out you have to remove the parking brake lever and use a wrench on it to get them adjusted fully asjusted."
I had the same problem. They are now working fine.
Old May 30, 2017 | 09:42 AM
jozw30's Avatar
Funny, you have two threads going in two different directions....just to add I tried all of the other things people will tell you to try and lost two months wasting money and time.
I changed MC to larger bore, triple checked the spacer pin behind the MC, bought a power bleeder, bypassed/blocked lines one at a time, verified pedal ratio...yadayada.
If you have little to no pedal and you feel that the lines are properly bled (including unbolting and turning them to get the bleeders up top and smacking with hammer...) then it's the e-brake adjustment on those rear Caddilac calipers.
Old May 31, 2017 | 08:03 AM
Thanks, jozw30 for the input. I will definitely try that. I've been told to try every single other thing you already tried. Glad you did all the RnD for me!
Old May 31, 2017 | 08:52 AM
jozw30's Avatar
I'll try to find the write up I used to adjust those things. The instructions sent with the kit do not get it done.
If you want it, pm your email address.
