rebuild LS6 or swap to LS3?
Old Jun 13, 2017 | 09:50 PM
Robcookz's Avatar
Default rebuild LS6 or swap to LS3?
Hey all,
I Have a 68 camaro with an 2003 ZO6 LS6 engine. The guy who built it went carbureted bit of a weird set up. Engine only has 5k miles on it from rebuild. I Dino'd it and it came in at 330 at the flywheel, it's also burning some oil which makes me think it wasn't built right. It runs great but seems to be Underperforming for what the engine should put out. Car is fully re built in great shape and I intend to keep it long term. Question i have is should I rebuild the LS6 with some internals to get it over 400rwhp or swap it out to an LS3 and move to a newer set up.
Let me kmow your thoughts
Old Jun 13, 2017 | 10:10 PM
Z28-4-Chris's Avatar
All depends on your budget.
For what it's worth, a cam only LS3 is easily over 400whp
Old Jun 14, 2017 | 09:20 AM
JIMB's Avatar
If the cylinders are within spec I would be tempted to buy a 383 stroker kit. You get more cubes than a LS3 and you don't have change anything else.
Old Jun 14, 2017 | 10:10 AM
JoeNova's Avatar
Restricted User
Stroker kits are very poor HP/dollar.
Old Jun 14, 2017 | 10:16 AM
psychosid30's Avatar
It's all about what you want to spend.
An LS3 495hp crate motor is @ $7200 right now. That is with a 58X reluctor wheel, which you will either have to change out your computer, get a converter box to change the signal to 24X, or pull apart your new motor and have the wheel changed out. You will also have to get adapters/extensions for some of the sensors to make it work with your wiring harness. You also might have to at the very least swap out the oil pan for your old one to make it fit your set-up.
You can pick up a Thompson Motorsports Stage 1 LS3 for @$6800 that will come with a custom grind cam and easily make your 400hp. It does not come with an intake manifold or a lot of the other stuff the crate motor comes with. You will have to get a rectangular port intake, LS2/3 front cover and valley cover, and several other LS3 specific pieces. You will be able to use a lot of the stuff off of your LS6 to help complete it. You will still need adapters/extensions, but you can have them build it with a 24x reluctor, so no need for that headache.
Money wise, it would be best to go JIMB's route (as long as your block is within specs for a re-build). For the price of swapping to an LS3 you could stroke your motor, buy a FAST intake/throttle body combo for it and you should achieve over 400hp. Check out Loren's (themealonwheels) Camaro build. His NA 383 stroker put down somewhere in the neighborhood of 490(ish) RWHP.
Old Jun 14, 2017 | 10:53 AM
1964SS's Avatar
Originally Posted by Robcookz
Hey all,
I Have a 68 camaro with an 2012 ZO6 LS6 engine. The guy who built it went carbureted bit of a weird set up. Engine only has 5k miles on it from rebuild. I Dino'd it and it came in at 330 at the flywheel, it's also burning some oil which makes me think it wasn't built right. It runs great but seems to be Underperforming for what the engine should put out. Car is fully re built in great shape and I intend to keep it long term. Question i have is should I rebuild the LS6 with some internals to get it over 400rwhp or swap it out to an LS3 and move to a newer set up.
Is this the info he gave you on the motor? 2012 is not an LS6 motor. I believe they stopped using them in 2005-2006. I would start off by checking exactly what you've got in that car.
Old Jun 14, 2017 | 10:56 AM
Robcookz's Avatar
sorry typo 2002 LS6
Old Jun 14, 2017 | 11:30 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
05 vette is ls2. 06 is ls2 and ls7. The only 05 car to use the ls6 which is the last yr is the ctsv.
The gto had swapped to the ls2 already.
Old Jun 14, 2017 | 11:38 AM
You would be into the entire project for alot less and less headache to rebuild your ls6. There is just so much more involved in the ls3 swap etc.
A full rebuild kit top to bottom front to back for that ls6 including every gasket, bearing, head bolts, oil pump, timing set, rings runs $650 shipped from us.
In comparison a set of forged pistons runs $650-900 depending on what you get of course.
That is the quickest and most cost effective way to do it.
Old Jun 14, 2017 | 11:45 AM
Robcookz's Avatar
Thanks for the advise. I'm prepared to budget 10k problem I have is once I do the stroker/rebuild + change back to a proper EFI (car is carburated now) it's going to get up there in cost. Probably close to the LS3 swap no? Or would you say still cheaper to do the work on the LS6?
The car has a T56 6 speed that I just did a new clutch in and a 12 bolt rear end. So would be just the engine swap and I could sell the old one?
Old Jun 14, 2017 | 11:48 AM
Robcookz's Avatar
thanks but I'll need to factor in the labour of the rebuild + the EFI to get away from the carburetor still cheaper then the LS3 swap?
Old Jun 14, 2017 | 11:51 AM
A stock harness and intake/fuel inj/tb fuel pump setup isnt going to cost you anywhere near that.
There is no need to dump more money into somethin just because you can budget it unless you want to for some other reason. a cammed ls6 engine will make plenty of power for what you have really.
Old Jun 14, 2017 | 11:56 AM
A full rebuild plus fuel inj kit would run half the price of just the ls3 crate by itself.
If you want more info, send me an email and we can get you an idea on everything minus the machine shop part of course.
Rpmspeedtech@gmail.com
Old Jun 14, 2017 | 03:34 PM
Project GatTagO's Avatar
Personally, if you have a stick shift, I would do a LS3 and GMPP matching ECU and harness kit. If you have an auto, I would still do whatever flavor LS3 crate engine that you want, and get a harness and ECU kit from one of the vendors here...
Andrew
Old Jun 14, 2017 | 03:39 PM
10k+++ for a 3-4k fix....
Old Nov 22, 2018 | 09:24 AM
BandDirector Blk98ZM6's Avatar
I put a crate '04 LS6 in my '98 Z28 and it puts down 400.1 RWHP, so I'm guessing somewhere around 450-460 HP at the crank. Something doesn't sound right if your LS6 is only 330 HP at the crank! You absolutely sure it's an LS6? Some of the LS1's put in the F-Body towards the end of their run actually had the LS6 block, but that doesn't make them an LS6 IMO. A true LS6 needs to have the LS6 heads & cam, etc. to make it a true LS6 and a true LS6 will put down a lot more than 330 HP in stock form. Is it possible you've got an LS6 block with LS1 heads/cam? 330-350 HP would be about right for that combination. When I did my LS6 swap, the LS2 was actually an option too, but there was just too much that needed to be done to make it work and an LS6 was pretty much a direct drop in. I'd imagine it's about the same for your set-up since everything's already in place for the LS6.
My vote is to rebuild the LS6 if it's a true LS6 w/LS6 heads-cam. If it's not, then weigh the costs of what it would take to get your LS6 to your power goals vs. an LS3...
Old Nov 22, 2018 | 09:28 AM
...wait...this is a 1 1/2 year old thread?! I didn't revive it, why was it at the top of the page?!
Old Nov 24, 2018 | 05:35 PM
chuckd71's Avatar
For any and all practical purposes I doubt you're going to be able to tell the difference between rebuilding what you have vs an ls3 once it's in the car. LS3 is already old news so if going for "newer setup" you'd be spending money in the wrong place.
By Brett Foote | 2026-06-04 05:00:17
