AC issues sanden 508
If you using the stock c10 evaporator the fixed orifice tube may be clogged.
What are your pressures reading high and low? what is your ambient temperature?
What is the temperature of the Condenser?
according to the r134a chart, your AC pressures are way off. (Google "r134a chart")
Looks like Ike there is a restriction somewhere. Probably the orifice tube like stated before.
the condenser temp will be proportional to the amount of heat the evaporator is pulling out of the cab.
Looks like Ike there is a restriction somewhere. Probably the orifice tube in the evaporator. like stated before.
did you pull a full vacuum before charging the system?
Did you use stop leak at any time, or the 134 can mixed with stop leak? It's a known issue to clog the orifice.
Youll need to pull a full vacuum for at least 30 minutes with a hot engine bay to remove all air/moisture. The pressures you listed could also be from air in the system.
"negative digits" isn't going to cut it.
