5.3 ls w/ 317 heads, intake and cam need advice
Old 06-27-2017 | 02:07 AM
Drgnsbrth1983's Avatar
Default 5.3 ls w/ 317 heads, intake and cam need advice
I bought a 5.3 ls motor a few months ago that I'm looking to put in to my 79 chevy k10 it came with 317 heads, 6.0 intake and cam I need some advice I'm looking to push equal or close to the same horse power as torque I know the way the motor sits now there's hardly any power to it what would y'all recommend I'm shooting for 600+
Old 06-27-2017 | 02:36 AM
tfi racing's Avatar
317 heads? A ton of boost...
Old 06-27-2017 | 02:41 AM
slocaddy's Avatar
Welcome, forced Induction.
Old 06-27-2017 | 06:16 AM
Suncc49's Avatar
317 heads aren't ideal for 5.3, but throwing boost at it will get you where you need to be
Old 06-27-2017 | 11:03 AM
BadgeZ28's Avatar
I have a 5.3 bored to 346 with 317's. It is designed for a turbo or blower. The 317 is a modified LS6 head with bigger combustion chambers. I run them to get the compression ratio down a bit. Be sure to use LS6 head gaskets with them.
Old 06-27-2017 | 02:30 PM
Project GatTagO's Avatar
If the plan is to stay NA, I would look for a cam that optimizes the dynamic compression ratio (low overlap).
Andrew
Quick Reply: 5.3 ls w/ 317 heads, intake and cam need advice
