Russell hose vs earls
Old Aug 7, 2017 | 08:26 PM
fast86gn's Avatar
Default Russell hose vs earls
I found the fuel fittings I need on Jegs, the 2 fittings I need are made by 2 different manufacturers, is the hose compatible, -6an?
Old Aug 8, 2017 | 07:59 AM
squarles67's Avatar
I've never had a problem mixing hose and fitting manufacturers
Old Aug 9, 2017 | 05:14 PM
rpturbo's Avatar
As long as it is the same style, yes, it will be fine, but you have to make sure that the fitting, is the correct style fitting, for the hose.
