Transmission Temp from pcm?
Old Aug 18, 2017 | 08:46 AM
silverado01's Avatar
Default Transmission Temp from pcm?
I have an 01 5.3L with 2000 camaro 4l60e. Installed in 82 Monte Carlo.
can I pull the transmission temp from the ecm? I know it is available on silverados.
Old Aug 18, 2017 | 08:54 AM
gagliano7's Avatar
I see the trans temp sensor pin 51 of the red connector. You would just need the temp sensor for the trans.
Old Aug 18, 2017 | 10:55 AM
squarles67's Avatar
Should be able to, there is a temp sensor in the trans already.
Old Aug 18, 2017 | 08:58 PM
TrendSetter's Avatar
You can either adapt a Silverado cluster that has a trans temp gauge or use an aeroforce interceptor or similar obd gauge
Old Aug 20, 2017 | 08:37 PM
Looks like the transmission connector has a temperature ground pin.
anyone know what pin that should connect to on the pcm?
