2007 or newer pcm?
Old Aug 21, 2017 | 08:23 AM
slimmeh's Avatar
Default 2007 or newer pcm?
Do the newer ecus saport dbc or do I need to find an older ecu?
My engine is out of a 2014 Tahoe DBW wanting to run cable throttle body.
Just want to know if the new computers are able to convert? or do i need an old ecu?
Old Aug 21, 2017 | 09:45 AM
EFIHARNESS's Avatar
newer ecu's only support electric throttle. Steve
Old Aug 21, 2017 | 10:16 AM
slimmeh's Avatar
ok so do the older ecu's have the same plug connectors?
Old Aug 21, 2017 | 10:17 AM
jcvett56's Avatar
The two are NOT interchangeable. Major electrical differences between the two engines prevent you from mixing and matching parts. You must use the proper computer and drive-by-wire pedal setup.
Old Aug 21, 2017 | 10:32 AM
slimmeh's Avatar
ok so that forces the issue of needing an electronic transmission then? or do they have an aftermarket standalone system that i could use on these newer 5.3l wiht a dbc throttle body?
Old Aug 21, 2017 | 11:37 AM
Project GatTagO's Avatar
Why do you want DBC? The DBW works awesome.
Andrew
Old Aug 21, 2017 | 01:20 PM
slimmeh's Avatar
i really don't wanna buy another tranny.
I have a 700r4 that's built up and it needs the tv cable hooked up
Old Aug 21, 2017 | 04:00 PM
psiconversion's Avatar
LS1Tech Sponsor
You can go DBC, but you have to switch it over to 24X. You can either change the Crank Reluctor Ring or use the Lingenfelter Box (Part # L460065397).
For this setup we use the Red/Blue PCM (like an LS1) and our Harness part # HAR-1059
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
