'67 GTO/LQ4 Swap
Old 09-10-2017 | 12:07 AM
Gretalives67's Avatar
Originally Posted by mytmouz
I just put a stock 67 SS hood on my 67 malibu with my LQ4 in place using the forward bias holley swap 9this allows me to use the factory ac compressor). All factory accessory drive, except for the smaller diameter power steering pulley, and a stock intake. Mine is drive by cable though, so I can't help with the pedal...
Thanks
Old 11-03-2017 | 04:29 PM
dublingto's Avatar
I have a 1967 GTO convertible. We used the 525 hp LS3 engine with a T 56 magnum 6 speed trans. The 302-2 Holley oil pan works great with good ground clearance and tie rod clearance. I used the stock trans cross member, but had to relocate the mounting tabs on the frame. I used the chevy small block frame mounts for the engine mount along with the Headman engine mounts. We had to cut the trans tunnel for it to all fit. The Holley engine accessory mounts work great. I also went with a hydraulic clutch and Hydroboost brake master. Except for the trans tunnel, I had no fitment issues except for the headers. I got my trans package from American Powertrain. I am using the Tanks Inc gas tank with in tank fuel pump and corvette fuel regulator. It all seems to work fine. I have about 2000 miles on the car so far. I was amazed at how often new products came on the market for these projects! If you can't find what you need, just wait about 6 months and someone will have it or have one better! Good Luck!
Old 11-03-2017 | 04:32 PM
dublingto's Avatar
I also used the Vintage AC and the newer steering box
Old 02-04-2018 | 09:06 PM
dublingto's Avatar
How is your project coming? any pictures?
Old 02-23-2018 | 09:13 AM
Project has kinda stalled (my fault). Going to try to stop by shop today and do a test fit of the DBW pedal. Will also (gently) pressure him to get the body on the rotisserie so I can have the frame back.
Old 03-01-2018 | 09:09 AM
Default Progress Pics
Nice to see my painter is taking me seriously. I don’t want a “friendly” car - don’t want it waving to people as I drive down the road.
Attached Thumbnails '67 GTO/LQ4 Swap-fc2e7e45-f54b-4274-af31-734fa2938c8f.jpeg
Quick Reply: '67 GTO/LQ4 Swap
