LS3 Front Engine Plates w/ Alternator and PS
I've been searching (but mostly with my phone) for some from engine plates that have provisions for both an alternator and power steering. So far I have only seen one with an alternator provision. I'd prefer to keep everything upper mounted like the Corvette drive is. Anyone have options they know of?
It's a full custom tube chassis. The current plates are setup for a SBC and are 1/2" thick aluminum. Unfortunately these won't be able to be modified but the rear wishbone mounts will.
I looked at them but they don't have the option for an alternator or PS provision....
I'm not sure what you are speaking about. Are you talking about the engine mounts or the accessory mounts? If you're speaking about the engine mounts, I will only be using the front plate/rear wishbone style. That's my only option and that's currently what was in use with the SBC in there. I just need a front plate setup with provisions for the accesssories I need. If not, I will have to modify the accessory brackets to bolt through the plate mount and into the engine itself.
Looks like it's this combo
http://www.racecraft.com/index.php?m...3873d2e4f9c9a5
http://www.speedwaymotors.com/F-Body...SABEgLl9_D_BwE
