Intellatronix VSS
Old Sep 9, 2017 | 08:43 AM
70_el_S_camino's Avatar
Default Intellatronix VSS
So I've done some searching but can't seem to find a straight answer to this. I'm putting a lm7 out of a 2004 suburban. I'm using my original th350 transmission behind it and need to have a VSS for the ecu. But my ecu has a green and purple high signal, low signal coming out but the intellatronix s9020 I was going to use only has 1 out put. Does anyone know how or if I can hook this up?
Thanks,
Corey
Old Sep 9, 2017 | 09:19 AM
garys 68's Avatar
The ecu uses a 2 wire sine wave input from the VSS. I've used the Dakota digital sender for this. From the ecu to the speedo is a square wave digital output.
I'm guessing your output is a digital square wave. I don't know anyone that's got a square wave output to work on the LS ecu.
Old Sep 9, 2017 | 09:46 AM
So the GPS I have won't work but for the speedo. Is there any cheap remedies for the ecu?
Old Sep 9, 2017 | 09:55 AM
garys 68's Avatar
Dakota digital has a sine wave, 2 wire sender that will screw into the th350 mechanical speedo output.
Old Sep 9, 2017 | 09:59 AM
Is it the gps-50-2?
Old Sep 9, 2017 | 10:04 AM
garys 68's Avatar
SEN-01-1
http://www.dakotadigital.com/index.c...rod/prd109.htm
Old Sep 9, 2017 | 08:24 PM
brandon6.0's Avatar
I wanna say the intellitronix vss is ment to be used with aftermarket gauges or there gauges. I wanna say u can hook up to the high side wire and it should work. Tune may need changing for it to work correctly.
Old Sep 10, 2017 | 05:02 PM
I'll check into that. Thanks for the responses.
