Speartech and a 4l80
Old Sep 30, 2017 | 10:30 PM
87c10's Avatar
Default Speartech and a 4l80
I just started hooking up my speartech wire harness (which is pretty nice ) to my 2003 4l80e ...I noticed my harness DOES NOT. Have the plug for the neutral safety? It has both vss plugs and the big round one . but nothing for neutral safety???? Do I need it ? What do I do ???? Its Saturday might and speartech won't be open til Monday.
Old Sep 30, 2017 | 10:56 PM
I would have the patience of Job, my friend, and wait until Monday to call SpearTech to see what is going on. I feel for ya man!
Old Sep 30, 2017 | 11:25 PM
JoeNova's Avatar
Restricted User
In most vehicles, the neutral safety is located in the shifter and prevents the starter from cranking, so most companies do not connect the neutral safety that goes to the trans/PCM which just prevents it from firing.
Old Oct 1, 2017 | 12:45 AM
87c10's Avatar
I'm gonna use a b&m quick silver floor shifter.......just more info on my install if it makes any difference. I originally had a colomn shifter. 87 c10
Old Oct 1, 2017 | 09:56 AM
Project GatTagO's Avatar
So figure out which wire on the 87 is the neutral safety switch wire. It is probably located in the column. Then just run that wire to a safety switch that is triggered by the B&M shifter.
Andrew
Old Oct 1, 2017 | 02:14 PM
350SS's Avatar
Xanax
