Florida is HOT - must--have--AC
I am swapping an LS 5.3 into a 97 Jeep Wrangler TJ and have some questions about air conditioning (AC).
The jeep currently has AC and I want AC after the swap. However, I don’t understand all the wiring that needs to be done to make it work.
Brendan over at LT1swap says to ditch the AC wiring. (I guess AC is not “cool” in Jeeps.) But, it’s HOT in Florida; AC is a must.
So, the questions are: how does the wiring need to be done in order to make AC work in the Jeep after the swap? Keep the AC compressor clutch relay control wiring in place? How will the Jeep AC levers and switches (wired into the Jeep harness) activate the LS compressor?
Thanks
Ted
Thanks
Ted
