Ls1 cruise control drive by cable or wire in corvette
What is needed pedal wise, brake switch, cruise module etc to make LS1 and Drive by Wire TB work in a Corvette c3 ?
I have Rostra 250-3020 early GM style closed circuit cruise control switch
Vz (gto) auto loom with drive by cable TB
I have a 04/05 vy Auto 12200411 PCM
The loom that came with the Engine was manual which has Drive by cable TB.
I got a Auto loom from a VZ commodore which has Drive by wire.
I either cut and modify the VZ auto loom to make it compatible with the Cable TB or use the new Wire TB which is better for cruise control ???
Anyone can suggest how to make all of this work ?
what kind of pedal do i need - one like this
http://www.ebay.com.au/itm/Holden-Co...gAAOSwhcJWJbOT
What kind of cruise control module works with the 411 PCM and cable TB.
Is the vss used from the trans or is a splitter needed
Any links and pics?
Thanks
Any links and pics?
Thanks
