Silverado 2006 HD2500 = DBW?
Old Oct 29, 2017 | 08:21 PM
mjollnir's Avatar
Default Silverado 2006 HD2500 = DBW?
Was the Silverado 2006 2500HD a DBW or DBC from factory?
Old Oct 29, 2017 | 08:28 PM
mjollnir's Avatar
Bonus question: does the TAC (integrated in the pedal) connect directly to the TB or is there interconnection through the ECU?
I can't find a 6 pins connector on my harness nor any DBW indications in my ECU schematics
Old Oct 29, 2017 | 08:29 PM
CattleAc's Avatar
DriveByWire
Old Oct 29, 2017 | 08:38 PM
mjollnir's Avatar
Thanks CattleAc
I followed pin 15 from Blue Connector. That leads to a Delphi connector with 3 wires while a TAC module for a 2005 Silverado has 6 pins. What's wrong here?
Old Oct 29, 2017 | 08:42 PM
CattleAc's Avatar
Your throttle pedal assy, "APPS" should have wires that go to the "TAC" module.
The TAC module should have wires going to the electronic throttle body, and the PCM.
Crude drawing...
Old Oct 29, 2017 | 08:44 PM
mjollnir's Avatar
Old Oct 29, 2017 | 08:55 PM
CattleAc's Avatar
What color are the 3 wires?
There should be three wires you don't need that are for the cruise control. Grey, Grey/Black, Dark Blue...
Old Oct 29, 2017 | 09:21 PM
mjollnir's Avatar
Blue/white
yellow/black
green
Old Oct 29, 2017 | 09:42 PM
CattleAc's Avatar
I don't see any wires with that color for the drive by wire wiring.
Would you have a picture of what your working with??
Old Oct 30, 2017 | 09:06 PM
mjollnir's Avatar
Pin 15 from PCM BLUE is the blue/white wire you see on that connector
Old Oct 30, 2017 | 09:47 PM
brandon6.0's Avatar
If that harness come from a 4x4 truck that would be your 4x4 front diff pigtail. Not needed on a 2wd swap.
Old Oct 30, 2017 | 09:49 PM
CattleAc's Avatar
Pretty sure that's the Crank Position Sensor connector...
Old Oct 31, 2017 | 07:04 AM
mjollnir's Avatar
Here is the connector on throttle body from truck:
Old Oct 31, 2017 | 07:16 AM
mjollnir's Avatar
Which is a truck TB. It has 3 holes and fits my LS1 intake.
Now I need to order the matching pedal/TAC (2003-2005 truck pedal), figure out the wirings and that's it I guess?
Old Oct 31, 2017 | 07:23 AM
mjollnir's Avatar
Like those:
New pedal/tac only:
http://www.rockauto.com/en/moreinfo....2658&jsn=10578
Amazon Amazon
Used complete assembly:
https://www.befr.ebay.be/itm/03-06-C...MAAOSwIWVY91n7
https://www.befr.ebay.be/itm/2003-05...wAAOSwVqlZ6jEX
Old Oct 31, 2017 | 07:27 AM
8.Lug's Avatar
You're mixing-n-matching components. It doesn't work that way; too many variations from model to model. Use the components for your PCM.
Old Oct 31, 2017 | 07:33 AM
mjollnir's Avatar
I got the PCM with the harness. I didn't get the pedal/APPS/TAC/TB with..
What is non-matching please?
Old Oct 31, 2017 | 08:12 AM
mjollnir's Avatar
I see they changed pedal/tac/wiring from 2006. My PCM is 2006 so I should order 2006-2007 pedal assembly
And my TB will probably useless as it's a 2003-2005 model
Old Oct 31, 2017 | 01:50 PM
CattleAc's Avatar
Your throttle body will work just fine...you need to source a TAC module and pedal assembly from a 2006. You be all set to go.
Old Oct 31, 2017 | 02:34 PM
mjollnir's Avatar
Yay! Let's order!
