Am I going to have 6.0 envy?
#41
Probably not as good tho.
The weird thing is I disconnected the controller and it idles ok in gear. I didn't drive it that way. Just back and forth in the driveway.
175psi at idle tho and 230+ in reverse.
I also was able to lower the idle to 900 which I never could do.
#42
That is distinctive how the high pressure made it seem like it loosened the converter. We need a trans expert now to tell us why or how it happens. I wonder if that was what I was seeing with mine without realizing it. I still haven't been able to play with trans settings because of school but I think there is a correlation and we can somehow control the in-gear "pull of the engine" by adjusting something.
#43
Been following along and enjoying the thread. FWIW -- I debated on engine size/selection when I did my swap last year. Finally bit the bullet and put a 6.2L in. The pain only lasted a short time.
#47
(Chuckle!) Adjust by putting a manual transmission in. Control then falls to your right hand and foot.
