5.3 no start
Old Dec 2, 2017 | 03:45 PM
Jason Mussleman's Avatar
Default 5.3 no start
OK I just installed a5. 3 I fired it up ran it a few seconds and shut it off now it will not start I have injector pulse good fuel pressure and spark ham a cam code 0342 low circuit I got 12v going to it and 2.5 pulsating got them reading on 2 cam sensors even at the computer same readings has a good ground to. Any ideas I thought either clogged injectors or timing off. Just looking for opinions
Old Dec 3, 2017 | 10:42 AM
ls1nova71's Avatar
Is the VATS turned off?
Old Dec 3, 2017 | 12:49 PM
Chased's Avatar
exactly I had this same problem a few days ago. Had it turned off and it fires though I know I have issues other then VATS
Old Dec 4, 2017 | 07:01 AM
The vats system should have been eliminated. I did send the computer off to get reprogrammed
Old Dec 4, 2017 | 08:28 AM
Suncc49's Avatar
well camshaft position sensor does assist with starting... unplug it , try to fire engine, possible bad sensor or wiring issue to that harness
Old Dec 4, 2017 | 01:05 PM
Camshaft position sensor is good. I looked down in the motor and the reluctant wheel doesn't look good. Guess I'm gonna have to pull the motor. And thanks for the help
