5.3 swap over fueling help
Ok guys I just finished a 5.3 swap in a 89 c1500 has a base tune I made to run it cracked run perfect had some small things had to change to get it to idle correct but that’s it. My first time using hp tuner also but I’ve had it running for about a week last night was going to crank it do a little tuning truck cranks goes dead I crank back is running really bad idle about 600 if u touch the gas it dies this is the same tune I’ve been running on take some plugs out have 3 that are black go get a set of plugs and change Those three injectors crank
back up runs the same take plugs out now all 8 are like this so I’m thinking maybe high fuel pressure i didn’t have a way to check bc I have an fuel line don’t have a adapter for the rail so I went got a new regulator and filter I’m jsomg
the corvette one come back change same thing im
almost down to the ecu have some issue what do y’all think
Yeah, it sucks they don't have a port on them somewhere. Here's what I did. Maybe you could do something similar. https://ls1tech.com/forums/conversio...-wagon-13.html Post 244
when you load scanner it allows manual over-ride of air fuel adjusting. Simply open the fuel panel and set the a/f ratio to something appropriate, something lean enough to start with. Then watch the wideband and work your way rich until you have 15's to 14's on the wideband. Engine will run good there, gota watch that wideband behavior.
Then see how far off it is. For example if your scanner shows 12:1 but wideband says 14.5:1, you know there is some adjustments need to be made in the tune. Getting the numbers to match is important for beginners because the air mass calculations are used for lots of other things like trans-shifting pressure and idle routine behaviors.
