4L60E Transmission on a LS1 Corvette engine HELP
Any help. This is all going in a 56 Chevy pick up on a Fat Man Chassis. I'm not sure about the flexplate in the vette though, I believe you'll need a f body flex plate.
You need a Ls 4l60e from 98 - 06 f body or two wheel drive truck. They have a 300mm input shaft and will have a bolt hole on the bell housing at the 12 o'clock position.
98-02 f body
99 (new body)-06 truck
In stock form they also have one extra clutch (7) in the 3-4 clutch pack. A 4l60e has (6). Which if doing a rebuild anyways is a non issue because you will more than likely set up your 3-4 clutch pack different than both those setups. Meaning for a performance application you can use a 6,7,8 or even 9 clutch set up and have much tighter clearances than stock.
How much power you plan on making ?
Randy
Randy
