Replacing LS7 crate with LS3 crate, what is involved?
As far as I know the physical dimensions are the same except for the oil pan so everything else should fit and hook up properly.
The question is the engine controller kit, 19166567 is an older version and has now been succeeded with a newer version, 19354334. I don’t know what the difference is but my plan was to buy the current LS3 kit, 19354328, and just swap the ECU’s and then be able to use the rest of the parts for my next LS7 project. Would that work?
Thanks
Yeah, I know about the dry sump LS3 in the G/S C6, my father in law have one of those, maybe I should visit his garage some night
I have plenty of space except for ground clearance, as it is now the oil filter is the lowest point under the car even if it's just barely. The dry sump LS3 seem a bit tricky to find though but I think a wet sump using the regular Corvette oil pan would work as well
