Front coil springs
Old Feb 1, 2018 | 07:09 PM
a70oldscutlass's Avatar
Default Front coil springs
Would anybody happen to have the part #for the front coil springs in a 70 A body when doing a ls swap?
Old Feb 1, 2018 | 07:33 PM
Small block springs should work, as even they are a bit heavier than LS engines
Old Feb 1, 2018 | 07:40 PM
Someone said they mad some just for ls swapped A body cars so I thought I would see what everybody used.This research stuff is very time consuming for someone that can barely turn on a computer and can't remember anything.lol
Old Feb 1, 2018 | 07:52 PM
You might check with some of the aftermarket suspension outfits, like BMR, Hotchkiss, Spohn, SC & C, etc.
Old Feb 1, 2018 | 09:32 PM
Michael Yount's Avatar
I promise - it's even MORE time consuming if you CAN'T turn on a computer.
Old Feb 1, 2018 | 09:44 PM
Ach1992880's Avatar
My 71 cutlass sat about 1/2" higher after the swap from 350 olds with original air conditioning to the iron block LS. It's not a big difference.
Old Feb 2, 2018 | 07:04 AM
1964SS's Avatar
Iron block LS will not be much lighter, but if you swap to an aluminum LS motor then you will sit quite a bit higher. Easiest method is to do the swap and figure out how much lower you would like your front end to sit. The front springs on an A body can be cut so if you are on a budget you could cut a coil off. There are several lowering springs available as well so if you are using stock ride springs and it sits too high then buy 1" or 2" lowering springs.
If you aren't on a tight budget and want the best ride height possible (fully tune-able) and a great ride then I suggest a set of coil overs. I installed the QA1 kit on my chevelle and I absolutely love it.
