Drivers side low mount a/c solution
Old Feb 5, 2018 | 05:21 PM
unnatrl's Avatar
Default Drivers side low mount a/c solution
It's been a while since I looked for solution to a/c mounted on the drivers side, but finally found it. My current project is using the Holley turbo manifolds that won't fit with a stock compressor. The high mounted compressor might have worked, but it's really busy having a turbo and a/c compressor on the passenger side. The Nissan 300zx and 350z have their compressor on the drivers side from the factory. Naturally, someone built a bracket to retain the factory lines and compressor in the aforementioned cars. You have to use the Nissan compressor, but I suspect it's not a big deal as most of the builds hat are out there require custom lines.
Old Feb 5, 2018 | 05:27 PM
unnatrl's Avatar
I will keep trying to post the photos as I'm getting an error right now.
