electric fans
Old Feb 7, 2018 | 03:56 PM
65LS3's Avatar
Default electric fans
I'm not sure if this is the right place or not but I have a LS connect and cruise engine and I need to hook up dual fans. I have only one fan wire coming out of the fuse/relay box. Is there any way to make this work for dual fans?
Thanks!
Old Feb 7, 2018 | 04:13 PM
B52bombardier1's Avatar
Yes, dual relays. Make certain that your one wire coming out of the fuse box is thick enough gauge of wire to handle the amperage current for two fans - they need a lot of juice. Probably at least a 30 amp fuse but see if you can get a wattage or amperage number on your fans. Try to stay away from relays constructed overseas, regardless of price. Summit Racing and Jegs might have an already made up kit for you with different temperature kick on setups for each fan.
Plenty of You Tube videos and other circuit descriptions out there on relay strip construction:
Rick
