5.3 swap 91 GTA fuel system question
Hi I'm currently swaping my 91 trans am GTA from tpi to carbed 5.3. I am running all new fuel lines I was wondering if i need to run a return or not. I have a airtex e2000 inline pump I'm gonna be running with a regulator.
Just curious as to why the inline pump? When I swapped my 87 I bought a direct fit 255 for the tank. I also used the vette filter/regulator. Everything bolted up nicely and used all the stock stuff to boot.
Cypris isn't talking about using the stock pump, he's talking about using a Walbro 255LPH pump that just drops into place, just like the stock fuel pump, no modification needed. Using that plus "the Corvette filter/regulator" (search this site) is a quick, inexpensive (maybe $150 or so for both parts) & well-proven way to get a naturally-aspirated LS swap running.
If you're wanting to use an "airtex" (??) fuel pump with some unknown regulator, then I don't know if anyone will be able to give you a definite answer. I'd say that you'll probably have to run a return line, but it depends on your specific parts & how you set it up. Best bet is to contact whoever manufactures those parts & see what they recommend.
BTW, I'm spending the rest of this afternoon working to get my own GTA swap running...
OP, did the regulator come with instructions? I dont do carb'd engines, so not sure how an electric fuel pump that is constantly running at a set pressure wouldn't just push too much fuel to the carb without some kind of return?
He said he's running a carburetor, so a Walbro255 and a Corvette filter wont work for him, that will be about 10x as much fuel pressure as he needs.
