S10 LS Hedman 45900 Headers
Old Mar 14, 2018 | 04:26 PM
simman22's Avatar
Default S10 LS Hedman 45900 Headers
Before I purchased these headers I scoured the web looking for some actual info for how the headers look and how they fit. I wasnt able to find anything so I pulled the trigger and ordered a set. As expected, the passenger side when right in with the exception of the ear on my 4l80e, I had cut it off before but had to take a little more off. The drivers side took some rubber mount pursuasion and a couple of little dents to give plenty of clearance and of course the transmission ear. Here are some pictures.
Attached Thumbnails S10 LS Hedman 45900 Headers-4e4b123f-a8a6-430f-a4d3-8909605bdb48.jpeg   S10 LS Hedman 45900 Headers-94497900-dcce-4e9d-92c3-b1f231fdec8e.jpeg   S10 LS Hedman 45900 Headers-d7ff31a3-2d60-4f3a-b65c-e8d479a5b64d.jpeg   S10 LS Hedman 45900 Headers-818f9933-1ede-41a1-901d-457620b06ffa.jpeg   S10 LS Hedman 45900 Headers-fbfe4d19-5c36-487f-81e4-9515e6b0a465.jpeg
S10 LS Hedman 45900 Headers-0623b431-4241-474c-bd22-bfa069838dcf.jpeg   S10 LS Hedman 45900 Headers-50eb8430-a9e6-43e9-8d1c-f8b28bdb9d34.jpeg   S10 LS Hedman 45900 Headers-92f76e95-92be-4557-8603-330327a55d62.jpeg   S10 LS Hedman 45900 Headers-e9a5cc91-effc-4870-bc86-1340a651d5f5.jpeg   S10 LS Hedman 45900 Headers-2c2fa016-0bfd-49a2-8b0d-8c9637ef1653.jpg
Old Mar 15, 2018 | 08:27 AM
Cheese Weasel's Avatar
Thumbs up
I've tossed around the idea of LS swapping an S10, this is excellent info. And it's awesome that you included so many pics!
Great job!
Old Mar 15, 2018 | 10:24 AM
simman22's Avatar
I tried to find install pics of these bad had no luck and it’s hard dropping that much money in the hopes of it going right. If you go through with it and need any help let me know, I’ve used the trial and error method with a lot of parts to see what works best.
Old May 8, 2018 | 10:56 PM
Lil Psi's Avatar
Having gone through two different sets of headers that supposedly work seeing this make me feel some relief ordering a set tonight from Summit. I see your steering shaft appears to be a Jeep shaft? Could you help me out with that? My truck is a 97 and a lot of the info on this swap is for first gen. My set up is a 97 S10 SS is an LS1 with a set of Milled 317 heads and LS6 cam I had laying around, 4L60e built to 65 with a Trailblazer converter. Is my daily driver so should be fun.
Old May 10, 2018 | 01:27 AM
simman22's Avatar
Yeah, that should be pretty fun. All I did was get a steering shaft from a grand Cherokee that has the same oval shape (two flat sides and rounded ends) on the shaft. When you are looking keep in mind that you will encounter three styles, a square shaft one and two oval style ones. One of the oval ones will be clocked a different way. Once you find the right one then lay it next to the stock shaft and take a mental note of how much to cut off and pull the sleeve off of the stock shaft and weld it on the Jeep one. I didn’t take any pictures when I was making it but it will all make sense once you start looking at it.
Old May 10, 2018 | 05:32 AM
Lil Psi's Avatar
Thanks for the info! Wanting to eliminate the upper Tulip joint as well, so I guess is time for a trip to the Junkyard.
Old May 10, 2018 | 10:49 PM
toplessHO's Avatar
astro van shaft works too,will need to reclock one end.
Old May 12, 2018 | 09:37 PM
Lil Psi's Avatar
Well chalk up set number three that will not fit without majorly clearance pipes with a hammer. I am using Transdapt/Hedman swap mounts as well. This is my at least 7th LS swap into something it does not belong in and this one is winning! Getting ready to throw in the towel and sell it all! Thinking they worked so well on the Blazer due to the taller engine stands and taller body mounts.
Old May 13, 2018 | 04:01 AM
simman22's Avatar
What all are they hitting on? And what do you consider major for clearancing the pipes?
Old May 13, 2018 | 05:29 PM
Lil Psi's Avatar
Both upper control arms, driver's engine mount even with ears cut off and drivers floor pan. Engine is already as far forward as it can go oil pan to cross member clearance would be the next hurdle if I tried to move it forward. Would have to dent number one tube in at least 1/3" and approximately the same for cylinders three and cylinder six. Another issue I will run into is if I raise the engine driver side floor board will need to "massaged" with a hammer by at least a 1/4"
Old May 14, 2018 | 11:53 AM
simman22's Avatar
I had to massage the tube a good amount for the drivers engine mount but I have 2door 2wd Blazer specific mounts so I figured it was that. As for hitting the floor, have you tried adjusting the transmission down in the back? Mine is pointed down from the factory and I just made up for it with the pinion angle and have no vibrations, not even on the track with nitrous.
Old Oct 30, 2020 | 05:53 PM
Jacob Dummann's Avatar
Hey guys Im new to this page does anyone know how the 45900 headers fit on a first gen
Old Oct 30, 2020 | 08:06 PM
First gen WHAT? Corvette? Nova? Camaro? Malibu?
Old Oct 31, 2020 | 08:18 PM
rpturbo's Avatar
Since this thread is about S10's, I'm guessing first gen S10.
Old Oct 31, 2020 | 08:54 PM
Safe assumption, but not always a slam dunk on these forums...
Old Nov 1, 2020 | 08:40 PM
Yes guys sorry first gen s10 82-93 Im not sure what the frame /firewall clearance is compared to a second gen
Old Nov 5, 2020 | 06:13 PM
rpturbo's Avatar
You are ABSOLUTELY correct about that. I thought about that later. Hope that didn't come off as snide, because that certainly wasn't my intention. There are just some guys who don't know there are first and second gen S10's. They aren't everyone's cup of tea.
Old Nov 5, 2020 | 06:54 PM
Naw, you're cool... no offense taken...
