5.3 S10 cranking issues
I recently purchased a 5.3 S10 in running condition but last week I ran into some issues. Initially the truck ran great and would start with no problems however I noticed on a few ocassions that it would take 2-3 cranks before it would turn on.
Then on a morning while driving home the trucks suddenly dies on me. immediately I pull over to the median, put it on Park and try to start it again but no luck. At this point I’m sitting there for about 15-20 minutes and try again. This time it turns on and begin driving home. Half mile into driving I decided to do a quick pull and then smoke starts pouring into the cabin and the truck dies again. I quickly pull over and see trans fluid all over the street. Hose to the cooler came undone... At this point the truck was towed to my house. Once home I fix the cooler line with clamps and tighten everything up. Upon start up it doesn’t want to turn on once again. Finally after an hour or so it starts up and limp it to the back of the house where it finally dies again. From this moment on it hasn’t turned on again at all. Cranks fine but that’s about it.
I’m baffled and im not sure if someone has had this issue before. perhaps someone could help out.
Few things:
injectors could be dirty? I’m getting fuel to the rail...
I do have spark but maybe bad grounding? How could grounding all of the sudden go bad?
Thanks in advance
Did you de-grease it well? I hook a hose to the drain valve on my hot water heater and use a high pressure nozzle + simple green when I have a oil based malfunction..
Cosign pdxmotorhead's suggestion clean it and let it dry. That might solve your issue by itself. Hopefully no trans fluid got sucked into a hose or the intake.
