6.0 to TH350 mating question
SIDE NOTE: The car currently has a BOP TH350 and I know the LS based engines use a chevy bolt pattern. Will the Chevy TH350 bolt directly in place of the BOP TH350?
http://www.ebay.com/itm/New-Speedway-LS-Crank-to-GM-TH350-400-Converter-Sleeve-Adapter-4mm-Centerplate-/381141324137?pt=Vintage_Car_Truck_Parts_Accessories&hash=item58bdcb1169&vxp=mtr
if its flat you need this
http://www.ebay.com/itm/700R4-Early-4L60E-Adapter-to-install-a-LS1-motor-/130944454153?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7ce5ce09&vxp=mtr
you also need to elongate the converter bolt holes toward the center of the flexplate approximately 1/8 of an inch ,,, a rattail file works well for this purpose
