Crate ls3 easy steam solution
Old Mar 30, 2018 | 08:05 AM
Mrngwoodstewie's Avatar
Default Crate ls3 easy steam solution
This is a picture of the crate ls3 I bought. I know! This is beat to death but just want to get a warm and fuzzy and do this the cheapest way possible, also think this will be fairly clean looking. The oem steam port just above the right water pump outlet. Am I correct in thinking this can be down turned into that right hole because its the hot water returning to the radiator to then be cooled again? The air at that point will rise and find its way to the radiator cap. Thanks! All.
Old Mar 30, 2018 | 08:15 AM
If so I Imagine something like this would work well? ... correct size? (For the most part)
Old Mar 30, 2018 | 08:23 AM
And if that right one is the return and left assuming is cold inlet. Does anyone make a swiveled adapter or anything that would orientate it to the 45* range instead of the 225* it comes with?
Using my stock oem s2000 radiator which has both pretty much on drivers side.
edit: its actually a mishimoto aftermarket “stock” replacement but does have increased capacity with dual fans and shroud.
Old Mar 30, 2018 | 11:29 AM
Project GatTagO's Avatar
By far, the cleanest way to do it is to tap the water pump. I've done this on both the Cougar and my GTO.
Andrew
Old Mar 30, 2018 | 12:47 PM
Michael Yount's Avatar
You can see mine below -- comes off of the same fitting you ID'd in your pic above and "T's" into the upper reservoir hose.
Old Mar 30, 2018 | 03:28 PM
You T’d it into that expansion tank? It must hold pressure correct? Mine expansion tank does not hold pressure. Its just a plastic screw on but I know it will push and pull liquid to it and back on cool down or at least thats how I read it to work. But I know the steam vents must be under pressure or it would just boil over.
Red circle right?
Old Mar 30, 2018 | 07:03 PM
Correct - my reservoir is pressurized - you can see the 75 kPa cap on it. It's the high point of the system - and man does that make filling it easy. Just pour it in til it's full. Never an air pocket.
Old Mar 30, 2018 | 10:20 PM
gofastwclass's Avatar
I'm not a fan of modifying the water pump since it is a wear / potential failure item that may need to be replaced on a road trip.
My preference is the upper radiator hose or running the line to the cap side of the radiator factory style. The other factory option is the pressurized overflow as Michael Yount posted.
Old Apr 1, 2018 | 09:47 AM
JIMB's Avatar
I've done all three ways. Drill and tap the water pump, weld a 1/4" NPT into the radiator and the splice the upper radiator hose.
Taping the water pump works. My LS1 98 TJ has been like that for 10 years with no problems. Down side is as said above the replacement of the water pump. Also IMO bleeding air out the motor is more work since the steam line is running down instead of up to the highest point of the radiator.
The splice in the upper radiator hose works well if you have to splice the hose to get the bends in the hose to match the engine and radiator. Down side is two more places for leaks. Having said that I did this on a E36 LS swap and had no issues.
I think the best is welding a bung into the upper part of the radiator and then running a stainless -3? hose from the steam line to the radiator.
Note there are a number of different steam line configurations in regards to where the outlet of the steam points. IIRC correctly the later model truck LS engines have the steam line pointing straight out.
Old Apr 12, 2018 | 12:39 PM
-TheBandit-'s Avatar
I had a local shop weld an NPT bung near the top of the radiator. This is primarily to purge air, so the higher the better.
Old Apr 12, 2018 | 12:48 PM
I like that idea! I think many of the aftermarket radiators are coming with that now too.
