03 Ss Silverado
Old Apr 9, 2018 | 04:34 PM
xenaskyy's Avatar
Default 03 Ss Silverado
Wanting to know what has to be done to put out 07 LS2 out of a trailblazer SS in 03 Silverado SS
Old Apr 9, 2018 | 09:57 PM
brandon6.0's Avatar
Im pretty sure the ls2 is a 58 tooth. Grey sensor.
Your truck is 24 tooth. Black crank sensor.
So for this swap to work, u will need the lingenfelter 58-24 tooth conversion box. Also u will need to move the 03 model knock sensor to the side of the ls2 block. ( simple redrilling and adding longer knock sensor harness extensions).
Thin basic tuning. Reuse all your original trans, and accessories etc. Basic swap. May need to change small parts like oil psi sensors etc.
Old Apr 9, 2018 | 10:41 PM
xenaskyy's Avatar
what if I have the computer to the ls2 does that change anything? I also have the wiring harnessalsonhave all accessories on the ls2 also
