69 El Camino Ls swap
Hi,All, I need advice on installing trans cooler lines with interfering with the floorboard. I’m installing an LS3 engine with automatic trans in my 1969 El Camino and I can’t fit the trans cooler lines because the floorboard are to close. Anybody have any advice. Thanks.
Are u using braided line. I say a hammer works good for sheet metal massage but if not find a fitting from the trans with a 90 on them and try that but I prefer straighter lines and moving the floorboard
How much room are u needing to be able to hook up and unhook the lines without anything in the way 1 inch half an inch etc. If it's a small amount in just one or two spots u can u a punch to just massage it in the right spot instead of beating a whole 6 inch wide section. It will look better that way then touch up with paint and continue on
Thanks,I ended up using a 180 Degree hose fitting & a hammer. Now can anybody tell me how to remove terminals from the throttle pedal connector? I have no trouble with all the other connector.
