5.3L 4l60E swap
I do not have a ton of knowledge when it comes to transmissions especially when it comes to electronics. My question is, if I buy the engine and a 2wd 4l60e will they be compatible. I found a guy on Facebook marketplace that has a 2003 4l60e out of a Yukon with 130,000 miles on it for $300. If I buy that transmission or any other 2000< transmission will it work with the engine out of the 2007 Sierra. I know it should bolt up fine I am more worried about the electronics and the computer. Will the 2003 tranny work with the 2007 ecu or do I need to find a 2007 tranny to work fine with the engine?
What do you think about 4l60e vs 4l80e in as far as for a daily driver that will only be towing a few times per year? Would there be any mpg or longevity benefits for either?
Whichever transmission you decide on, a heavy-duty cooler would be a good idea.
Good luck!
