65 gto 421
Old May 4, 2018 | 08:46 AM
jwags01's Avatar
Default 65 gto 421
I am building a GTO and the engine is a 421 with about 600 hp. It came with a 4 speed Muncie, but it will not handle the horsepower. What manual transmission do you recommend? What will I need to mount it to the engine.
Old May 4, 2018 | 11:06 AM
Jimbo1367's Avatar
T56.Magnum
Old May 4, 2018 | 11:14 AM
Michael Yount's Avatar
How is the car being used?
Old May 4, 2018 | 11:19 AM
ForceFedC5's Avatar
OK, first I just wanted to say AWESOME CAR & ENGINE!! Please post pics!
Must be a "Transmission" day. This is the 2nd time today I'm recommending RPM Transmissions (765) 640-5411.
I've used them for 15 years for both manual and automatic and they've been beyond great.
Make sure to speak with Jeremy, he's always getting me the best bang for the buck, is honest and is actually an old school Pontiac enthusiast.
Old May 4, 2018 | 01:34 PM
jwags01's Avatar
Default 65 gto 421
First, thanks for the response. Car is being used for some street driving, show car, but I want to be able to take to track. I have seen the T56 as option. Will it bolt to the bellhousing used for the 4 speed muncie? Any other recommendations?
Old May 4, 2018 | 02:07 PM
Do you have highway rpm limitations/desires? Define "track" - autocross, road racing, 1/4 mile? You're gonna have a ton of torque -- so 6 gears aren't strictly necessary and the T56/6060 series is a big/heavy tranny with lots of parasitic loss (rotating weight). There are 5 speed options out there too -- might be a better "fit" -- unless of course you want 1300 rpm on the highway at 70 mph.
Old May 4, 2018 | 02:27 PM
jwags01's Avatar
If I bring to track, would only do 1/4 mile. A 5 speed sounds good to me!
Old May 4, 2018 | 02:59 PM
CattleAc's Avatar
Ok, so are we talking about a "421" cubic inch LS based engine...or, an original Pontiac 421...???
Old May 4, 2018 | 03:11 PM
jwags01's Avatar
Original Pontiac 421 - sorry, I know this is an LS forum.
Old May 4, 2018 | 03:23 PM
CattleAc's Avatar
Ok, I see. I think McLeod makes a "direct fit" 5-speed for old muscle cars that I think requires no cutting for install, and I think it will bolt up to your bellhousing...
Link
Old May 4, 2018 | 03:25 PM
pdxmotorhead's Avatar
DOnt see them talked about much on here,,, but,,
Reman Jerico, they come up on the Oval track for sale pages.. and at Oval/dirt track swap meets, the big teams run them for a season and trade them in each winter.. There are 2/3/4/5 speed variants.. Not "cheap" but very rebuildable and they handle some serious power.
Old May 4, 2018 | 05:21 PM
Sounds like you're going about it the right way -- I'd pony up for a TKO600 with the gear ratios you want and add the "shifts like it should" option that many perform with this. Much smaller/lighter/more efficient than the 6 speed and should hold up to your demands. Pretty sure I've seen a bell for this application - BB Poncho to TKO.
Jericho, Nash and Richmond options - but they're gonna be noisy.
Old May 4, 2018 | 05:48 PM
Use smaller mufflers,, then the tranny noise won't matter.. LOL
Old May 6, 2018 | 07:52 PM
joyridin''s Avatar
As stated, go with the TKO with the .82 OD. I think it is considered the close ratio version. There is another option with the .64 OD, but it is a huge drop between 4th and 5th and unless you have EFI, your car will not like the .64 OD.
