1969 Camaro L99 with 6l80
I recently purchased an L99 w/6l80 out of a 2012 Camaro i am trying to doa budget friendly swap into my 1969Camaro which i know is difficult to do on these swaps but i wanna try to save some money where i can. The engine is equipped with afm/dod and vvt. I want to keep the afm/dod(i know i may get some slack for this) but hey lets be honest gas aint getting any cheaper and i wan to have that gas saving feature avail. Not to mention i like the ac blasting on those hot days.
So my question is do i need any addtl equipment for the afm/dod to work correctly? The engine did not come with an ecm/ecu or cats. As i noticed PSI stanalone wiring states you need to have complete emissions setup for everything to work.
DOD and AFM are two names for the same thing. "They" deactivate cylinders to turn a V8 into a V4.
The only issue is i want to keep the afm/dod i want to make this a budget friendly swap. Making these dod deletes get pretty pricey.
My question is if i wanted to keep the afm what do i need to make it work? Cats,emission system,etc.
Unless there is no way around it or i would have to spend more on keeping the afm/dod than the afm/dod delete.
check out link for my current update on this build:
https://www.camaros.net/forums/241-l...ing-stage.html
L99 does not have dod . It has VVT (variable valve timing) . It has the same lifters as the ls3. Mast motor sports has an ecm/ harness and will supply you with a base tune. You might need a 5 th gen ecm for the trans to shift . Maybe psi for the harness with stock ecm?
Yeah for sure confirmed several places the L99 came with dod/afm i will more than likely will be doing the gpi stage 1 cam i dont want to change the torque converter im already spending a lot of money on other components which was expected just trying to save where i can.
I am trying to find the proper angle for the transmission as i am building my own transmission crossmember I was checking out a lot of apps and reading on the angles but a lot if expects for me to have a driveshaft already, can i skip this step or is there anyway around it?
